Group: DynoMotion Message: 10197 From: Rjreese29 Date: 9/24/2014
Subject: Re: CNC4PC's New C68 Adapter makes a number of BOBs KFLOP Compatible
A real nice device.
I have been dreaming of closing my loop on a linear glass scale and now It can be done because of this device.
Arturo and Tom really made this happen for me.
Thanks again for the prototypes Arturo!!! And  thanks Tom for the support in c programming and the kflop!!
Now I just to work out some of my own bugs in my system and I know I will be happily making really accurate chips and parts in the next couple weeks!!
Thanks for your equipment, support and patience,
Rob
On Sep 23, 2014, at 5:10 PM, tk@... [DynoMotion] <DynoMotion@yahoogroups.com> wrote:
CNC4PC's New C68 Adapter makes a number of BOBs KFLOP Compatible.
The C68 Adapter basically provides a pinout equivalent to a PC Parallel Port or Smooth Stepper to make KFLOP easily connect to boards or systems that are setup for that physical/electrical arrangement.
Also available are configuration and C Programs that allow Mach3 or KMotionCNC operation nearly plug-and-play out-of-the-box to support basic devices like Step/Dir Drives, 0-10V Spindle control, and MPGs.
Check it out.  It looks like CNC4PC did great work.
Group: DynoMotion Message: 10199 From: ericncn Date: 9/24/2014
Is this device the only way to connect linear glass scales?
I have been dreaming that too, but my understanding was that the Kanalog could do that too.
EC
---In DynoMotion@yahoogroups.com, <rjreese29@...> wrote :
A real nice device.
Rob
Group: DynoMotion Message: 10200 From: Moray Cuthill Date: 9/24/2014
Eric,
you can connect linear scales directly to the KFlop.
Either via the relevant pins on JP7, or JP5, which are both 5V tolerant.
I used JP5 for my little probing machine, as JP7 is used by the KStep. You can see how I acheived it at http://www.machsupport.com/forum/index.php/topic,27732.msg196260.html#msg196260
You only need a Kanalog if you want to make use of differential inputs, however most common scales I looked at are not differential.
Moray
On Wed, Sep 24, 2014 at 3:58 PM, ericnc@... [DynoMotion] <DynoMotion@yahoogroups.com> wrote:
EC
A real nice device.
Rob
Group: DynoMotion Message: 10203 From: Tom Kerekes Date: 9/24/2014
Hi EC,
No this board is not required to use linear glass scales.
Group: DynoMotion Message: 10204 From: Rjreese29 Date: 9/24/2014
Yes Tom. Thanks
My application is specific to having an existing c23 breakout board in my system. This made it possible for me to only have to replace my previously existing controller with the kflop and it made the the kflop integration very easy. It is compatible with multiple cnc4pc bobs.
Rob
On Sep 24, 2014, at 10:30 AM, Tom Kerekes tk@... [DynoMotion] <DynoMotion@yahoogroups.com> wrote:
Hi EC,
Group: DynoMotion Message: 10405 From: ericncn Date: 10/28/2014
Ah, I see.
I was talking having my own system in mind, my motor encoders have a differential output, and also the glass scales I was looking at, are differential.
A different question: could a C68 be used together with a KAnalog?
I assume it can't - it looks me they are mutually exclusive - but would like to be certain.
EC
---In DynoMotion@yahoogroups.com, <moray.cuthill@...> wrote :
Eric,
Moray
Group: DynoMotion Message: 10414 From: Wcarrothers Yahoo Date: 10/28/2014
So this is equivalent to say operating or converting a system that is presently
Parallel port > to gecko
Now is would be kflop > c68 > gecko
Perhaps also adding the ability to close the encoder loop?
So it takes the kflop outputs and makes to pulses look like 5v parallel port pulses?
Guess I'll add this to the list of stuff I want on the shelf.  Although my machine that I run parallel with geckos also has a smooth stepper and I tend to run it in parallel mode more then use the stepper
B
On Sep 23, 2014, at 8:10 PM, "tk@... [DynoMotion]" <DynoMotion@yahoogroups.com> wrote:
Group: DynoMotion Message: 10421 From: Tom Kerekes Date: 10/29/2014
Hi Bill,
Yes that is correct.  If you have existing breakout boards or cabling that were designed to connect to parallel ports (or Smooth Stepper) this should make it easy to connect to KFLOP without have to do any custom wiring.
Group: DynoMotion Message: 10422 From: Wcarrothers Yahoo Date: 10/29/2014
Cool.  You endorsing this product and assume you have been given one to test and all?
On Oct 29, 2014, at 5:16 PM, "Tom Kerekes tk@... [DynoMotion]" <DynoMotion@yahoogroups.com> wrote:
Hi Bill,
Group: DynoMotion Message: 10424 From: Tom Kerekes Date: 10/29/2014
Hi Bill,
We are not formally endorsing it.  Any issues with it should go to CNC4PC.  But it is in our interest to help support it.  I know of at least one happy User.
Group: DynoMotion Message: 10425 From: Wcarrothers Yahoo Date: 10/29/2014
Ok. Just wanted to check.  Assumed there was a bit of collaboration   Just wanted to dig a bit for info.
B
On Oct 29, 2014, at 5:42 PM, "Tom Kerekes tk@... [DynoMotion]" <DynoMotion@yahoogroups.com> wrote:
Hi Bill,
Group: DynoMotion Message: 10431 From: arturodu Date: 10/30/2014
Bill,
The C68 is a very simple board.  It basically re-routes the pinout of the Kflop to the pinout we use in our controllers. It makes it very easy to change motion controllers without having to rewire the whole cabinet. The main idea behind it is to promote the use of our breakout boards with it.  Specially our C32 and new C62 boards. Next we will have available the new version of the C68 which will add compatibility of the Kflop with leadshine drivers.
We offer money back on our products, so if you are not satisfied with it you can return it for a full refund.
It is not my intention to hijack this group to promote our products, I just wanted to let guys know I will be around in case someone needs a hand with them.
Arturo Duncan
http://cnc4pc.com
Group: DynoMotion Message: 10432 From: Wcarrothers Yahoo Date: 10/30/2014
Thanks.  I figured it was some what a bridge between his and your boards. But also was thinking there might be some magic in it converting signal voltages or something along those lines.
Are there ribbon plugs to db25's that would then plug into this board?
I finally have my second kflop machine coming up and will be using the kmotion interface this time.  So I see the writing on the wall of going to my first machine which is is still parallel at some point and switching it to k to standardize things some more
Right now it is able to run parallel or smooth stepper by selecting parallel port switch boxes to the motor drives.  But. I hardly ever used the ss.  Never really felt like an advantage with this machine so continued to run it parallel 99% of the time for the last 8 some years.
If these would allow easy connection to db25 from the headers that would make it drop in even easier
B
On Oct 30, 2014, at 7:39 AM, "aduncan@... [DynoMotion]" <DynoMotion@yahoogroups.com> wrote:
Bill,
Arturo Duncan
Group: DynoMotion Message: 10440 From: arturodu Date: 10/31/2014
B,
Yes, you can use ribbon cables to go from the IDC26 connectors to the DB25 to emulate parallel ports:
Arturo Duncan
http://cnc4pc.com
